It is currently Sun May 19, 2013 5:51 pm
PostPosted: Thu Mar 25, 2010 7:45 am
Recently noticed a "tinney rattle noise" under car, and sounds like a heat shield? My car is
a stock '98 metro 3 cyl. This rattle noise has been occuring about 2 weeks now, and just yesterday morning and today have noticed a lack of power going uphill. Has anyone had trouble with a Cat Converter pluging up exhaust? Am fairly new to metros, so any input would be helpful, thanks!
PostPosted: Thu Mar 25, 2010 4:46 pm
I see more plugged cats on these cars than good ones. Usually due to low compression and burnt valves. I suggest you perform a compression test. The is a guide in the howto section.
Image Image
  • Project Page - Click Here
  • Modified Suzuki 1.0L Engine
  • 2" Suspension Lift & Weight Reduction
PostPosted: Sun Jun 05, 2011 11:05 pm
I have been noticing a squeaking/high pitch rattle also at only select low rpms and especially from a stop. When under the car it sounds like it's coming from the cat but when I manually shake the exhaust with the car off I don't hear anything? could it be something on the engine? any advice on what tends to loosen up on the bottom engine area/exhaust/cat area? thanks
PostPosted: Sun Jun 05, 2011 11:07 pm
i also get an exhaust resonation at 2.5 rpms, with engine load . however car passed air care with below average emissions .
PostPosted: Sun Jun 05, 2011 11:22 pm
Mine passes easily as well. I have done the compression test but I think I have a lot of carbon buildup as my #s were 210-220 so idk
PostPosted: Mon Oct 08, 2012 1:25 am
Check out my recent post as one remote possibility in this thread:
viewtopic.php?f=22&t=18007
PostPosted: Mon Oct 08, 2012 7:25 pm
Check the resonator. Mine fell apart internally. Sounded just like a cat.
:lol: welcome to post from 2010
98 swift big block
03 cobra bolt ons
too many others to list
