It is currently Wed Mar 29, 2017 3:53 pm
 Post subject: front turn signals
PostPosted: Fri Jun 14, 2013 5:37 pm
wjch front turn signal you like the most?
stock european ambar (light darkened) or improvised clears using european gti mk2 reverse light cover
 Post subject: Re: front turn signals
PostPosted: Fri Jun 14, 2013 7:02 pm
If the driving lights were clear, then go with the clear signal lenses, otherwise I think it looks better amber and looks less "busy" that way.
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Fri Jun 14, 2013 8:29 pm
I'll trade you fog lights =)
08 Civic Wife's car
PostPosted: Fri Jun 14, 2013 10:20 pm
brand new crystal clear north american domestic market depo oem replacement turn signals run about $20us for each side.
clear lenses with amber led lamps look great with the glass e-code headlights and european corner lights.
PostPosted: Sat Jun 15, 2013 4:50 am
thnaks t3, can tou tell me the link were i can check tohore oem replacement crital clear depo?
PostPosted: Sat Jun 15, 2013 5:08 pm
a closer look of the clear ones
PostPosted: Sat Jun 15, 2013 5:25 pm
get a little of yellow vinil and wrap it :D
PostPosted: Sat Jun 15, 2013 6:11 pm
good idea, those screws are off centre up to the top, i've never seen that?
08 Civic Wife's car
PostPosted: Sat Jun 15, 2013 7:25 pm
i use the yellow vinil on my fogs...........
like i said, i used the european mk2 reverse light lens, like the one on the pic
i screwed the oem turn signal on the bumper, and then used mk2 eurpoean gti reverse lens with the srews off center , in order not to damage the lens :D
PostPosted: Sun Jun 16, 2013 11:23 am
chromed turn signal
PostPosted: Sun Jun 16, 2013 5:30 pm
http://www.ebay.com/itm/GEO-METRO-SPRIN ... 2202wt_806
http://www.ebay.com/itm/GEO-METRO-SPRIN ... 1902wt_806
http://www.ebay.com/itm/89-94-93-92-91- ... 2079wt_776
http://www.ebay.com/itm/89-94-GEO-METRO ... 2079wt_776
PostPosted: Sun Jun 16, 2013 7:25 pm
thanks man :D
PostPosted: Mon Jun 17, 2013 7:08 am
it´s usual here in Portugal, we use the european mk2 gti reverse lens to fabricate the clear front indicators....................for those who don´t know :D
just the final product before instalations on the car
