It is currently Tue Oct 17, 2017 8:22 am
Post new topic Reply to topic  [ 78 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue Oct 03, 2017 7:13 pm
There is shifter locker rod in the steering wheel (beside the key cylinder)... It might be issue...
Just disconnect the cable and lift the rod up and you will never have shift locked. :shock: :lol:
PostPosted: Wed Oct 04, 2017 11:52 am
its not the cable in the steering column-that one works fine.
I don't like bypassing certain safety features-if it aint broke, don't ''fix'' it.
most likely the interlock solenoid- this body has well over 340,000 km
but I haven't dug any deeper into it -yet- :-P
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Thu Oct 12, 2017 2:31 pm
on the week-end, changed oil&filter.
then onto the shift interlock- after some diagnosing and reading the fsm, I went over the wiring.
turns out it was a poor connection in the engine bay at the transmission- cleaned, lubed and now it works properly.
3 tech 6*gear
gti brake swap
Users browsing this forum: Bing [Bot] and 6 guests
