You began this thread like this:
Stampy wrote:
I just had a 1986 Suzuki samurai with a 1.3 rebuilt because of this.
What the hell does that mean?
This car acts like it is really lean at slow speed and refuses to idle or start. I checked for vacuum leaks and I had a shop check for vacuum leaks and their are none. I rebuilt the carburetor and nothing changed. The float level is correct in the sight glass and everything looks clean. The fuel cut solenoid is opening as it should.
Now, I replaced the engine computer and it ran much better and idled ok once you rev the engine to 2000 Rpm and let off.
Makes one think it is the ECM or the ECM connections, eh?
Now for the wierd part. I replaced the mixture control solenoid and it runs much worse than it ever did before. It runs leaner than ever now.
Obviously, the MCS is now the problem.
I am curious what I did wrong by replacing the mixture control solenoid?
The LAST thing you did is what screwed it up.
I need to pass California smog so I am gonna put the old solenoid back in.
Makes perfect sense. Consider yourself a 'parts swapper' at this point.As we enter page 2 of the thread, it sounds like it wasn't running right from day one.
Stampy wrote:
6 months ago when I bought this car It idled but didn't drive well under power. Come to find out the carb was flooding out the venturis.
How did you COME TO FIND THAT OUT?So I rebuilt the carb and installed it. Then the car would not start without starting fluid.
That means you screwed up the car with your carburetor rebuild.IT ran lean super lean assuming it ran at all.
What are you using to determine if the engine is running lean or rich?
I must have some vacuum leaks or a low float level.
This is you thinking out loud, right?Nope. So I went to a local junkyard and pulled another carb off of a samurai and rebuilt that one too. I got the same results.
What if you would have just put it on WITHOUT rebuilding it?An engine that runs super lean if at all.
Hear we go with that lean 'defecation' again.The simplest solution is usually the answer. I looked for vacuum leaks as best as I could. Plugged every port connected to the intake and vacuum checked everthing that plugged into the intake. No leaks. Later I took it to
Precision Automotive.They are a reputable shop. Which one? I told them to look for vacuum leaks for one hour. They used a dealership style smoke machine and said they couldn't find any significant leaks.
So does that mean they found 'insignificant' leaks?They also swore it was a carburetor problem and wanted to rebuild it for me. I pried the samurai away from them and towed it home. It did run better after they tuned it. It didn't idle but It ran better. The engine was peppy now and breezed past 20 Mph. I vowed now not to touch their idle or mixture screw settings. An ECM I bought off of ebay arrived.
Why did you buy it?I Plugged it in and now the engine idled. It was rough high and lean but it could idle.
Did you think to take it back to the shop and say, "Hey, I swapped in a new ECM, can you take a second look?The engine also had good power now and breezed past 20Mph.
So I tried a new mixture controller thinking that would get me the rest of the way towards a normal running car
logical assumptionand I ended up right at the beggining again. No idle and not enough power to creep past 20 mph.
sure sounds like the MCS is the root of your problem.One would think this must be the wrong MCS. I tried putting in the old MCS and nothing changed.
Everytime you touch the carburetor, it seems the car takes a dump. However, reading these two posts gives me a clearer picture of the situation.
My problem is interpreting your posts. You think you are explaining yourself clearly, but what is in your brain is not getting clearly into mine. That's why a forum is so helpful. Many brains make light work.
You keep mentioning that it runs 'lean'.
What type of test equipment are you using?
Next,
do you have a Mighty Vac vacuum tester?The $20K smoke machines that I'm thinking about are used to check for intake gasket leaks and vacuum leaks
WHEN THE ENGINE IS OFF.
imaiden found that the root of his problems was a bit of corrosion where the wiring harness plugged into
the ECM. If this was a part of the problem in your vehicle, then swapping in a different ECM might have helped. He bought one of the cheaper varieties of vacuum pumps from Harbor Freight and it turned out to be a bad move. Once he took it back and got the Mighty Vac variety, he was able to determine he had a bad vacuum advance.
You rebuilt the carburetor and it ran differently or the same?
I've quoted two posts of yours and you are like that Oxygen Sensor, flipping between 0 and 1 volts.
It may still be a bad MCS, but it is best to cover all the bases.
Looking carefully through your document, the word 'compression' only shows up in my signature.
If you intend to pass smog, you'd better go back to the beginning and post your compression test results.
Last, when I say post pictures of your work, I meant it.
Show us what you are working on.
We can't help you if you give us the least amount of information you possibly can.
Remember, you took it to a professional shop and they couldn't figure it out with the entire car in their possession.
Show us the under the hood, in the hood, whatever; the routing of the vacuum lines, basically everything under the hood.
Honestly, we only have a small picture of what you are dealing with.
Every car brought to this forum eventually gets fixed.
It is just a matter of time, patience, and working in a logical fashion.
A picture of the dash, for example, might not seem important to you, but it tells us a lot.
We can ask about how the radio is wired into the dash, and Samurai's will have plenty of aftermarket communications/entertainment devices wired in.
One simple mistake in adding an aftermarket device could be the reason you're having problems.
The guys helping you are no fools. They've confronted problems like yours and figured them out.
Give them the benefit of the doubt and approach this car with more logic and less emotion.
...and after it passes smog, make sure to stick around and give the rest of us a rash of sh*t.
We do have a sense of humor once the wrenches are back in the box, but if it isn't right, we can get real
focused.
I'm sure this vehicle can pass smog from what little we've heard.
How old is the catalytic converter (cat)?
