It is currently Fri May 24, 2013 3:42 am
PostPosted: Fri Nov 28, 2008 6:01 pm
Many of us have come across studs broken off...excuse the terminal preposition. Here's an example:
Let's say you were changing the O2 sensor...an MK1 is shown below:
Next you find that one of those little bolts has been broken "off" inside the exhaust manifold:
So what should you do?
Most guys just put it back with two bolts, or leave it off.
Some people have claimed that the "easy out" is the way to go. But I've tried many times and had no luck with an 'Easy Out'...
Some need expensive tools, or will send it to a machine shop.
Others weld something on, and wrench on that.
But what if it's flush, or recessed a bit?
Finally, an example showed up, so I thought I'd run through a quick, easy, and safe way to do it yourself.
First, drill a pilot hole into the center of the broken stud:
Now that you've got a good start, continue all the way through the old bolt. Here, I've placed the correct bolt next to the pilot hole, so you can see how deep to drill.
Some people get scared that they can't hit the center of the bolt. Others are worried that they'll mess up the threads. Just using a hand held drill, and with the exhaust manifold on an upside down trash can, it wasn't too hard for me to get it pretty close to center. No big deal if you take your time. No big deal if you aren't perfectly centered.
Now...we're into it about 7 minutes. Here's a blurry picture of what the hole looks like as I change to a larger bit. Notice that the bolt is getting pushed into the threads of the exhaust manifold. There is no danger to the threads.
Again, a few minutes later, the second drill bit has passed through the bolt. Although a little blurry, you can still see lots of metal between the drill and the threads.
Now, we pass still another drill bit through the hole, this time rendering the old, sheared off bolt paper thin. This allows us to put a tap through the threads, and that breaks up the last of the bolt. It's slow going at first, but once you get the tap started, it's a piece of cake to turn it in a few turns, and then clean out the pieces, and so on, until you end up with this:
Just in case you are confused about what kind of tap I used, here's a picture of it being used to clean up the threads on the lower part of the exhaust manifold:
The time to do this entire 'job' was less than 30 minutes.
I've read well meaning posts which have side-stepped or 'poo-pooed' this method as being too tough for the average individual. The tools I used here were ordinary tools that are commonly available.
You'll never know how easy it is until you actually try it.
PostPosted: Fri Nov 28, 2008 6:46 pm
I did just this last week. Except I attached the tap into my cordless drill. Makes it faster.
PostPosted: Fri Nov 28, 2008 7:21 pm
Bought heat treated bits for this very reason. I use this safe method often, as I feel this is the safest and cheapest way. 8)
Down but not out, fighting my way to the top again.
2000 Ford F350 SuperDuty Dually
2002 Ford F350 SuperDuty "The Beast"
1989 Suzuki Swift GTi "My PocketRocket"
http://www.pitbullfabrication.com
PostPosted: Mon Dec 01, 2008 9:41 am
Very nice writeup PnE. Too bad we don't have karma anymore :(
Any chance a mod can move this over to the FAQs section so it doesn't get lost in the insanity of Problems and Fixes?
-Bob
PostPosted: Mon Dec 01, 2008 2:54 pm
Ha!
Cheer up, it's almost Christmas.
Nice thing about Karma is that it changes.
At least we haven't been banned.......yet! :lol: :lol: :lol:
We should ask Santa for some Karma...and some new '3 tech' head bolts.
I found the thread of the guy who had a problem earlier this year. He could have used this technique...and Suprf1y's bolts.
Once you take the time to do this, it reminds you to put your stuff together right the first time!
Enjoy:
viewtopic.php?f=22&t=38025
And be thankful you didn't have his Karma.
For those who didn't get it the first time, here's a hint:
"See no evil, hear no evil, speak no evil, have no fun..."
Next time, use this technique and pull out those broken studs!
PostPosted: Mon Dec 01, 2008 5:24 pm
Destroyer of Databases/One man, one post
i'm tellin'!!!!!!
you called her "have no fun!" :lol:
1991 Blue Geo Metro Convertible highly modified 1.0L Turbo3 5 spd. - 2000 Chevy Metro 1.3L MPFI automatic. - 1991 Red Geo Metro Convertible customized 1.0L 5 spd.
PostPosted: Mon Dec 01, 2008 6:56 pm
You're a smart man!
She's a physician too, but not my wife, just one of her classmates in Med School.
Picture was taken in the Chinatown section of San Francisco.
Ha!
Fooled you.
And as far as having no fun...
She ain't got no boyfriend, far as I can tell. :shock: :o :shock: :o :shock: :o ...has never had one.
Talk about strict upbringing.
Makes me wonder how she's escaped all the horn dogs the past 30 years or so.
Now if she'd broken off 5 studs into the block...whoa! Now there's a babe!
...that's what I call a WAX JOB! :wink: :wink: :wink:
PostPosted: Mon Dec 01, 2008 7:00 pm
I've used a Dremel with a small carbide burr to do the same thing. You can shave the inside of the bolt down thin enough so that only the outer threads remain. You can then pick at it, and extract a corkscrew of metal that used to be the old bolt.
PostPosted: Thu Dec 04, 2008 5:28 pm
Great Job Phil, this topic should be stickied in the How To Section :thumbsup: :thumbsup: :thumbsup:
1993 Suzuki Swift 1.3L GA
http://www.pctek4you.webs.com
PostPosted: Wed Dec 24, 2008 7:12 pm
It's Christmas even and JV&S is out in the cold shop pulling a "phil"...
worked great thanks phil
GV&S
t3 ragtop wrote:
suprf1y wrote:
G-Whiz wrote:
I don't let just anyone work on my cars. Like the saying goes, "You don't let another man mess with your wife, so why would you let him mess with your car".
Users browsing this forum: Calrenman, Google [Bot] and 4 guests
