It is currently Tue Jun 18, 2013 6:43 pm
PostPosted: Sun Aug 26, 2012 1:39 am
hey guys!
i have a 93 Barina here in Aus and im running an 8v sohc carby engine :)
the bottom end is great and doesn't make a peep but the valve train is a little noisy when she gets hot. i want to put a Dohc head on it.
no i know i will need to change the headers and intake and get a wiring harness and ECU for the new head. im probally going to use the MK1 harness and stuff so i can use the vacuum dizzy on my 8v head. that is depending on how much it will all cost.
im not really keen on getting a whole new engine as the bottom end is still in good nik.
my question is do i have to get a new fuel pump? does it need a bigger one?
if i have missed anything what else would i be up for on this, as in what other parts would you recommend under the hood?
PostPosted: Sun Sep 02, 2012 7:18 pm
the g13 dohc 16v engine is a different critter from your 8 valve. there's more magic in the twincam block's internals than there is in your 8 valve's bottom end.
i know that you really don't want to drop in a complete new engine, but that will be the easiest and it's your best bet to get to a 16 valve engine. :wink:
1991 Blue Geo Metro Convertible highly modified 1.0L Turbo3 5 spd. - 1991 Red Geo Metro Convertible customized 1.0L 5 spd. - 1992 White Suzuki Swift GT
