It is currently Fri May 24, 2013 3:11 pm
 Post subject: msd???
PostPosted: Fri May 06, 2011 7:57 am
hey i have a 8910 can i use that or do i have to buy a 8910esi ? i have a swift gti dohc 1.3 with a ss blaster n a 6a msd
jd
 Post subject: Re: msd???
PostPosted: Thu May 12, 2011 1:58 am
Either should work. I used the ESI one on mine.
PostPosted: Sat Sep 03, 2011 1:18 am
do they make an MSD for the 94 3cyl?
PostPosted: Sat Sep 10, 2011 9:44 am
No i don't think so !
zquiet | zquiet
PostPosted: Wed Oct 19, 2011 5:54 pm
is there any ignition upgrades at all for a 94 geo metro 1.0 i3
PostPosted: Thu Oct 20, 2011 1:33 pm
An MSD can apparently be used on a 3 cylinder if it's set to 6 cylinder wasted spark. Search some of t3 ragtop's post for more info on this.
PostPosted: Thu Oct 20, 2011 4:11 pm
I was running a Jacob's Ice Pak for a while,
only problem was I was toasting caps & rotors
every 3000 miles.
I would imagine any other increased spark ignition
upgrade would do the same thing. I'm running
a Blaster coil right now, and seems to be fine, though
not nearly the spark that the Jacobs provided.
PostPosted: Thu Oct 20, 2011 10:28 pm
looking to improve milage, how much are they?
PostPosted: Mon Oct 24, 2011 8:06 pm
ok i called MSD they told me to get itnition box
Part # 5520 http://www.summitracing.com/parts/MSD-5520/
and Blaster ss coil Part # 8207 http://www.summitracing.com/parts/MSD-8207/
then i called summit racing and asked if they had a Summit brand version of the box. They said yes and the part # is 850610
http://www.summitracing.com/parts/SUM-850610/
soooo which box is better?
PostPosted: Tue Oct 25, 2011 5:33 pm
Destroyer of Databases/One man, one post
actually, the stock ignition on the 3 banger is pretty good, sufficient for the engine for the most part.
on a 94 the ignition is controlled by the ecu. if you connect the msd spark control to the module in the distributor you will lose the ignition mapping. if you use the signal from the ignitor that's internal on the ecu you retain the ignition mapping but just add the multiple spark from the msd with no real performance gains. the msd coil to replace the stock coil isn't too expensive but the msd spark control breaks the bank.
it looks cool and all but i figured that there were better performance gains that could be had for that kind of money. sink the cash into a 3 tech performance cam and a 2" exhaust. :wink:
1991 Blue Geo Metro Convertible highly modified 1.0L Turbo3 5 spd. - 2000 Chevy Metro 1.3L MPFI automatic. - 1991 Red Geo Metro Convertible customized 1.0L 5 spd.
PostPosted: Wed Oct 26, 2011 3:15 am
ive got a headers and a 2" exhaust
$135 doesnt for a msd setup doesnt really break the bank lol
im not looking for performance just fuel economy
idk y my reply came up twice
PostPosted: Fri Nov 11, 2011 9:31 pm
ok so how do i install this thing
