It is currently Mon Jan 22, 2018 1:31 am
 Post subject: Surging throttle.
PostPosted: Fri Jul 11, 2014 11:22 pm
So I recently purchased a chip from Teeth that would re-enable my closed loop. I finally got around to installing it today and I'm having a little bit of an issue atm and it appears he is on vacation for a little bit and is unavailable. So in an effort to not have to remove the ECU again just because he is gone and it is such a PITA to remove the ECU I'm going to post this here.
So I installed the new chip tonight and it sounds really great my idles is really smooth and on target and it seemed like it opened up things a lot the sound is absolutely a nasty snarl when I rev it up. So I finished buttoning it all up and took it for a test drive and that is where things get tricky, the car is super responsive it revs and accelerates really fast the problem is that whenever you aren't laying into the throttle the engine revs constantly. When you are at a complete stop it idles silky smooth but as soon as you are like coasting or just sort of feathering the gas it is really hard to deal with because it starts revving and jerking unless you take it out of gear and just let it coast while it is revving or put your foot back in it then it just jerks the car quite badly.
Any thoughts on how to sort this out?
Just to clarify this is not a complaint about Teeth! He is awesome, I just need a little help with this issue since he is unavailable.
89 Suzuki Swift GTI
15" Lancer OZ Racing Rims
Custom Trailing Arms by Dethbrd
Boxed Rear Control Arms
Super Pro Poly Bushings
Genie Header
Nissan Intake Manifold
2 1/4" Exhaust
Turbine Tech Underbody Brace
Honda CRX Front Brake Calipers
 Post subject: Re: Surging throttle.
PostPosted: Sat Jul 12, 2014 8:35 am
Make love, not moderators
It sounds like his tune is just way too aggressive.. TO be honest there may be nothing wrong and you will just have to learn how drive it with the way it is tuned.
PostPosted: Sat Jul 12, 2014 8:52 am
I don't think so for example lets say I was coasting down a hill with the car in 4th gear clutch still engaged and you might touch the gas a little from time to time to maintain your speed.
Well instead of just smoothly going down the car will jerk really hard and then cut and jerk and cut and jerk and cut and the engine revs up and down all by itself. It is basically undrivable while it is doing that.
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Sat Jul 12, 2014 9:29 am
Check your coolant, not sure if it's related
There may be an air bubble in the cooling system
08 Civic Wife's car
PostPosted: Sat Jul 12, 2014 10:22 am
I did a little more testing and when you press in the throttle and hold the revs at say 2K then it will drop to 1K and back to 2k and back and forth etc. If I got to 4K same thing 1k, 4k, 1K, 4K, wherever I have it pressed into is where it revs to.
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Mon Jul 14, 2014 8:29 am
I went back to the original chip and the car is still having the problem so I don't think it is ECU related anymore. It may just be coincidental that it happened right when I was trying out the new ECU. Anyways, I'm guessing it is something TPS related, but I'll keep digging.
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Mon Jul 14, 2014 5:39 pm
the idle adjustment is a dance among the idle air screw, the tps, and the fast idle controls.
a lot of times it is just like amer said, check the coolant. the twincam, among it's idiosyncrises, is really hard to burp. it keeps air bubbles where it shouldn't and that can cause the idle to surge as you described.
i got tired of that action so i used a blocking plate to replace the idle air control at the rear of the intake manifold.
i no longer have a fast idle but i also no longer have any idle surge. :wink:
PostPosted: Mon Jul 14, 2014 6:20 pm
You wuss! I just yank off the hose when the engine is up to temp, let the air flow out, and stick the hose back on. 8-) And pray I don't get a burn!
PostPosted: Mon Jul 14, 2014 9:02 pm
What is the best none "just yank off the hose" method for burping the twin cam? :huh:
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Mon Jul 14, 2014 9:09 pm
Honestly just driving the car SHOULD get the air out.
With the car upto temp you can try squeezing one of the rad hoses to "pinch off" flow through them, thus putting more flow through the smaller coolant hoses. Sometimes that works, but I usually just pull the hose off with it running, and it burps it out real quick, slip it back on, and re-install the clamp.
I should mention I do this with the rad cap off so there is no pressure in the cooling system.
PostPosted: Tue Jul 15, 2014 4:29 pm
dude! that would get sticky coolant all over my powder coated naughty bits! =)
PostPosted: Thu Jul 17, 2014 7:48 am
Is there a disadvantage to removing the idle air control?
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Fri Jul 18, 2014 7:36 pm
Turns out it just needed the experience hands of a professional. Dropped by my mechanic and he had it running super smooth in no time. It runs really really well, the idle is just a touch rougher than it should be and he said I need a new idle air control valve I believe. I looked it up on rock auto and that isn't the thing he was showing me so I must have gotten it wrong. He was pointing to that little black canister looking thing bolted onto the firewall on the right side of the intake with the hoses and adjustment screw on it. Anyone know what part that is I need to get?
Besides that, I am really pleased, the chip from Teeth works awesome and my idle is lower, and smoother, also it is not running nearly so rich anymore which were my goals for the moment.
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
PostPosted: Sat Jul 19, 2014 12:24 am
i take those off and throw them away. :wink:
it's pretty much a part of the a/c system and i don't run a/c.
PostPosted: Sat Jul 19, 2014 7:33 am
Lol thanks Richard!!! =) Unfortunately that plan of action wouldn't work to good for me. I just fixed my A/C, you know I have to keep the woman happy. Personally I could have done without it, but then I hear a lot of "Get rid of that old piece of junk and get a nice new car..."
Does that mean you have a pile of takeoffs I can have? :P
89 Suzuki Swift GTI
Genie Header
2 1/4" Exhaust
