It is currently Sat Mar 17, 2018 3:01 pm
PostPosted: Fri Feb 19, 2016 3:06 am
I'm completely inept when it comes to electronics.
I want to swap out the color of my gauge clusters from the original green, to something of my own taste, but, I don't know what I'd need to change them? Does anything just plug right up? (Probably a stupid question.)
Thank you, much.
PostPosted: Fri Feb 19, 2016 9:06 am
# 194 led bulbs- many different styles out there. it is a pain pulling the dash- disconnect speedo cable at trans, 2 screws to remove knee bolster plastic, two nuts to drop steering column, remove 4 screws from trim bezel, unplug rear defroster (if you have it) remove another 4 screws from gauge cluster, unplug speedo cable from rear of cluster, then unplug 3 large wiring connectors from rear of cluster. not lots of hand room back there.
led bulbs are polarity sensitive, make sure they work before putting all of the dash back in :blackeye:
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
