It is currently Mon Mar 19, 2018 3:55 pm
PostPosted: Mon Aug 07, 2017 2:29 am
So, I have gathered most of the rear wiper components for my car. (Rear wiper arm, motor, switch, glass and harness) I still need the dual pump reservoir for under the hood. My question is this: If my car lacked a rear wiper from the factory, should the wiring harness for the rear washer be under my hood? I know I needed the rear wiper harness and have that. Just don't know if I need to pick up anything to connect up the 2nd washer motor (which I do need still). Being overseas, I don't have my car with me to look myself. Thanks in advance.
'94 Metro LSi 'Green Machine'
'94 RHD (Totaled)
Vail, AZ
PostPosted: Tue Aug 08, 2017 3:08 am
I am 100% sure that Geo Metro has everything (both main harness and reservoir) so you only need to install rear wiper assemble parts and switchers.... just plug and play.
I did check my based trim MK3 Swift GA that contains everything except switchers and rear wiper assemble parts. Therefore I am not too sure about MK2 and or Geo metro but they should be... Pretty easy to check... check for spare connectors and matched wires.
sorry bout my bad english
PostPosted: Tue Aug 08, 2017 2:00 pm
there should be an extra/rear pump plug-in wire attached to the front pump wiring harness. the plastic tubing should be there as well. at least it is there on my 92 metro......
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
