http://teamswift.net/
87 sprint turbo banjo bolt size
http://teamswift.net/viewtopic.php?f=32&t=63013
Page 1 of 1
Author:  FloridaEdd [ Tue Sep 12, 2017 4:47 pm ]
Post subject:  87 sprint turbo banjo bolt size
So it's been almost a year since disassembley and I lost my oil feed line banjo bolt which attaches to the block to feed the turbo.
I'm so close but without this bolt I'm a million miles away.
Please help a brother out
Author:  FloridaEdd [ Wed Sep 13, 2017 2:12 pm ]
Post subject:  Re: 87 sprint turbo banjo bolt size
Found a banjo bolt in town but I need to know the internal hole size so I can fill this one and drill it to the appropriate size.
Author:  FloridaEdd [ Fri Sep 15, 2017 6:48 pm ]
Found my original bolt. But if anyone ever needs to know the hole is 77/1000ths on my dial caliper not sure what that translates to.
Author:  suzukitom [ Fri Sep 15, 2017 11:36 pm ]
Glad you found it. :thumbsup:
79/1000 is 2.00 mm.
Author:  FloridaEdd [ Sun Sep 17, 2017 3:38 am ]
Yeah I feel better having the original bolt.
I appreciate the conversion to mm, thank you.
Author:  FloridaEdd [ Sun Sep 17, 2017 2:38 pm ]
So I measured the hole in the bottom of the bolt but the hole at the top is 1.25mm. Just wanted to make sure I out the correct info out there.
http://www.phpbb.com/
