It is currently Fri Feb 23, 2018 12:20 am
 Post subject: WTB: 250-270cc injectors
PostPosted: Sat Apr 26, 2008 2:38 am
The stock injectors and maxing out, and im getting about a 13.8AFR on the top end at only 11psi on the RHB5 setup, so I'm looking for some slightly larger injectors that are under 300cc, as my MX6 turbo ones are a bit too much, and I cant get it much outta the 10's AFR wise on 18psi, so I'm looking for a middle ground here. They must be the denso's that plug into the factory injector harness as well. Located in edmonton, would like some ASAP if possible.
Thank you
Clyson
MK2 Firefly -- RHB5, SAFC Neo, 626 Turbo Injectors, Custom Equal Length Manifold.
SOLD!
PostPosted: Wed Apr 30, 2008 12:58 pm
what fuel pressure are you using when you are maxxing them out?
the lolcar family
