It is currently Tue Aug 22, 2017 11:52 am
PostPosted: Tue Aug 27, 2013 2:58 pm
Every 2 years i get my MR. SUZUKI Convertible rust sprayed to keep it in good shape.
I use KROWN spray on it good stuff .
Some pics :D
THE MR . SUZUKI CONVERTIBLE /// SIGNED BY MR .SUZUKI
at CAMI Automotive 2006 / 06 / 06
See The MR. SUZUKI Convertible here >>>> viewtopic.php?f=36&t=24728
or here >>>> http://geometroforum.com/topic/5577648/1/
PostPosted: Tue Aug 27, 2013 3:57 pm
jason, that's the only way to preserve one of these cars - constant applications of rust proofing and keeping them off of wet and salt laden roads.
the condition of your vert as shown in your pics says it all, my friend. :wink:
PostPosted: Tue Aug 27, 2013 4:32 pm
I'm jealous of your original floor pans.
Looks fantastic!
'91 Vert... Rebuilt 1.0, Clutch, KYB GR2 Shocks, Control Arms, Tie Rods, Motor Mounts, Wheel Bearings, Black Topper, 14" LuxAlloy Wheels, Bad Red Paint
PostPosted: Sun Nov 03, 2013 5:51 pm
Wondering if I should get my rust free 89 gti krowned
The only reason I don't want to is because it will make the engine bay all dirty once dirt sticks to all the oil.
My car is being stored in a car shelter which I have sealed the bottom and up the sides with poly vapour barrier...other than that the car shelter exposed to temperatures....I am hoping the vapour barrier keeps out much of the moisture in the air....
I know this car was religiously maintained by Tommy, apparently he would smear gear oil all over it, and not drive it on the rain, or wash it. I also don't drive it in the rain. And I have never washed it really....
Your thoughts?
___________________
89 Swift gti
PostPosted: Sun Nov 03, 2013 9:00 pm
I would spray it .
Better to have some dirt than rust .
If you dont it will slowly rust from the seams inside - out in our climate here.
PostPosted: Tue May 13, 2014 6:44 pm
I simply use a radiator brush... No spraying...I do the same as you... every 2nd year I smear rust oil on the underside of the car. Takes me a full day of pain staking work, but worth it...
