It is currently Fri May 24, 2013 7:37 am
 Post subject: MAF Housing
PostPosted: Tue Apr 24, 2012 10:18 pm
Besides boring the stock maf housing... any alternatives?
I remember someone a long time ago saying the 94-99 4.6l Mustang ones fit perfect and the gt sensor screws right in.
02 Aerio 2.3 swap Wife's car
 Post subject: Re: MAF Housing
PostPosted: Wed Apr 25, 2012 9:20 am
A legend in his own mind
I have a 50mm NISSAN one that I modified to accept the GTI sensor but the tuning was all outta wack.
I remember that it didn't take much to get it to fit and it was VERY close to the original...
Lemme know if you want it or can use it.
2013: this is gonna be an interesting year...
LNLC Founding Member
PostPosted: Wed Apr 25, 2012 9:34 am
OP, why do you want to modify the MAF signal?
~the other Ralph~
Certified Suzuki Owner:
PostPosted: Wed Apr 25, 2012 9:26 pm
upgrading the MAF to a larger one(regardless of which sensor element is used) will require remapping the fuel. It's as simple as that.
1994 Suzuki Swift GTi
PostPosted: Fri May 04, 2012 8:59 am
Correct swifted, and I just wanted to add that remapping the fuel without the proper data logs and/or a wideband afr device is a hit and miss activity. And if you miss badly, bye-bye engine.
There are also quite a different number of devices available to tune the fuel....not all of them are made equal. A guy that I know (good guy) is offering his own brand at a very competitive price and its also a very solid unit. This is the link, if any are interested >>> http://www.14point7.com/UAFC.php
~the other Ralph~
PostPosted: Mon May 07, 2012 9:08 pm
I remember seeing a couple of years ago the MAF of an Isuzu luv pickup. it was hitachi. And it looked a lot like the swift one.
1989-GTi: JE 75mm 11:1 pistons,Ported head,Suzukird single UD pulley,Sandros 210/340 chip,Aluminium flywheel,3tech 222/365 cams,Apex I S-afc,Genie headers,Cultus IM,50mm tb,Crane cams adjustable cam gears,B&G suspension.
1991-GTi: Cultus headers, Single UD pulley,Sandros Chip,3Tech 210/340 Cams,Cultus IM, 4.39fd GB, Apex springs.
2001-Altezza AS200: Stock.
PostPosted: Wed May 09, 2012 11:27 am
as long as it uses a 0-5v range, you can use any MAF from any car, just use its plug and splice it to the swift loom.... since you have to tune fuel anyways you might as well just get what evers available/cheap that is bigger, not that going bigger will do much for anything unless your turbo'd or highly strung NA
