I searched but only found info on the g10 cam/timing belt swaps.
Anyways I pulled the belt and the cams on the weekend after setting the crank pulley to 0 and the timing marks on the cam pulley's were also lined up.I pulled the cams and installed the regrinds with #1 lobes opposed as the stockers were,been sick so I'm just getting to putting it back together.
When I reinstalled the cam pullies just now the timing marks are out with both pullies pulled together the same amount( about a tooth and half each) off of where they should be with valve spring pressure from another cylinder-have I got something out of whack?
I'd like to get this baby back together so I can stick it in the car so if anyone can help me out that would great.Btw my computer is whacked right now and I can't open most manuals/diagrams etc thats on the net so I'm not able to find the stuff myself.
