It is currently Wed Jun 19, 2013 5:56 pm
PostPosted: Thu Jan 12, 2012 7:44 pm
So the question is does cultus gti camshafts fit to a standard g13b head with original camshaft pulley, or does it have to be an adjustable pulley, and do I need to tune/mode/adjust something else?
PostPosted: Thu Jan 12, 2012 9:46 pm
As far as I know they bolt right in place of the stock G13B shafts. I dont think a tune is necessary but you would see more improvement out of the cam swap with adequate tune.
Chris
'00 Integra Type R 84k miles I/H/E p/s & a/c delete ITRawrr ~ Because Racecar
'92 Swift GT 5 spd 116k milesRollin on Enkei 92's Currently getting some love :D viewtopic.php?f=4&t=50519
'91 Vert 5 spd 235K+ miles MOMO wheel Alpine Type R 12" - Alpine 500W mono amp H&R lowering springs & KYB struts
'89 S10 Blazer B&M ratchet shifter BUILT 350 smallblock hedman headers 6AL ignition Lowered 4/5 on 15" Weld Racing Rims
PostPosted: Thu Jan 12, 2012 9:47 pm
cultus cams are just a part of the equation. the cultus also had higher compression pistons, a special header, and completely different engine management (with a knock sensor.)
you can drop the cams into a gt engine but without the other magic parts, don't expect the same results.
1991 Blue Geo Metro Convertible highly modified 1.0L Turbo3 5 spd. - 1991 Red Geo Metro Convertible customized 1.0L 5 spd. - 1992 White Suzuki Swift GT
PostPosted: Sat Jan 14, 2012 5:51 pm
Not to mention the cultus intake manifold!
Just get with suprfly and get a cam from him, I do not think the cultus cam is that radical in all reality (I might be wrong).
Chris
PostPosted: Fri Apr 20, 2012 10:01 am
From what I understand the cultus cam has same lift as the non-cultus gti cam, but with 1 degree more duration. If you do get a set of adjustable cam gears and with some proper tuning (spark & fuel) you can make some decent power up to the mid 7k rpm.
~the other Ralph~
Certified Suzuki Owner:
PostPosted: Fri Apr 20, 2012 3:48 pm
Make love, not moderators
Actually they do have more lift. I have verified it with a micrometer.
PostPosted: Fri Apr 20, 2012 10:07 pm
I stand corrected....good to know!
~the other Ralph~
PostPosted: Sat Apr 21, 2012 9:10 am
here are the specs,
http://tighecams.com.au/bikes.htm
click Suzuki, then GTI.
14.84 @ 93.89 with No ITB's, No standalone computer, No dog box, Stock MAF, Single TB and Street tires all in a complete mk2. not bad eh!
PostPosted: Tue May 01, 2012 1:27 pm
swifty92 wrote:
here are the specs,
What cams are BD.10 and BD.14?
~the other Ralph~
PostPosted: Tue May 01, 2012 8:44 pm
bd10 and bd14's are different profiles of cams. the bd 10's are extremely close to suprfly's 210/340 cams which are a great street/strip/race cam. the bd14's are more aggresive but many have run them on their daily drivers. Both of these cams will give you great top end with some loss in the bottom end. More so for both with the bd14's. i have run the 210/340 cams and made power till 8600 rpm.
PostPosted: Wed May 02, 2012 7:22 pm
I have the BD10's and like them but you are money ahead (and supporting a forum member) to just buy a set of regrinds from Superf1y. I only have mine as they came in one of the GT's I have had- My other G13B will end up getting a set of his regrinds eventually.
PostPosted: Fri May 04, 2012 9:12 am
Yeah I know they're different profiles, I should have clarified. I was really asking what application/engine they came with, or whether they are aftermarket cams or reground cams.
With the Sandros chip and 210/340 cams, is there any great loss in low down power, say for city driving? I understand that the 210/340 need to idle @ 1100rpm to be happy?
~the other Ralph~
