It is currently Fri Jan 19, 2018 11:56 am
 Post subject: Badass camshaft!
PostPosted: Thu May 07, 2015 1:31 pm
What is the most badass camshaft for the swift gt dohc out there? Want do use original valves, pistons and lifters. No not care about running perfect on idle.
Anybody that have an idea? So manny out there. Catcams, pipercams, suzukird.
 Post subject: Re: Badass camshaft!
PostPosted: Thu May 07, 2015 1:53 pm
There is no better profile for the money than our 222/365
PostPosted: Fri May 08, 2015 9:07 am
Mike's 222/365 profile kicks ass and sounds amazing!!!! Ran it for two seasons so far in the race car and won the Championship with it this year!!!!!
PostPosted: Sun May 10, 2015 6:22 am
Yup! The 222/365 is just the perfect cam for your GTi! A lot of power kicks in between 4000-4500rpm.
I recommend using these cams with sandro's chip (rev limit 8600rpm).
2003-EVO7 GT-A
PostPosted: Thu May 21, 2015 12:12 am
What is the ball park price for Mikes 222/365 cam? I assume several have purchase this cam and are using it.
PostPosted: Thu May 21, 2015 3:37 am
$300/set on your cores, add $100 if ground on my supplied cores, plus shipping, about $25-$30
PostPosted: Thu Oct 20, 2016 12:08 am
Are these still being made?
PostPosted: Thu Oct 20, 2016 5:38 am
Yup. We're still here
PostPosted: Mon Aug 28, 2017 11:23 am
I also recommend the 222/365. It is a very linear cam, power just keeps on coming!
G13B 1.3L 16v 115hp
PostPosted: Sun Sep 10, 2017 9:01 pm
Here in portugal the most common camshafts are from catcams model 604, they make good power
PostPosted: Mon Jan 15, 2018 3:57 am
hi!! i would like to buy this camshaft, how do i order??
