It is currently Mon Feb 19, 2018 3:53 am
PostPosted: Sat Sep 03, 2016 4:57 pm
Entertaining offers with or without parts cache
My 1990 Vert, AKA Speque. Used parts cache.
Assuming you know the basics, here are some of the mods to the car - include; GT seats, new top, new tires, new brake pads, and timing belt with in the last year. Upper and lower grill inserts, Fog lights, HID hi/lo, 2nd gen valve cover (painted), Aluminum 2 row radiator, aftermarket radiator fan, 1.3 flywheel, aluminum under belly brace, ft and r sway bars, extensive sound damping from the firewall to trunk, cut outs for 6x9 in rear side panels, Alloy wheels, arm rest. Have a freshly painted drivers front finder not shown.
Used parts cache include; Cut GT ft springs, OEM Vert rear springs, spare rebuild-able head w/cam, Stock steel wheel set, 3 stock geo hub caps, 2 map sensors, ft sway bar, 1 set trunk remote release off a sedan with gas cover remote, spedo gear, Assortment of dash control-nobs-buttons, stock radiator, 1 aluminum radiator, stock fan, stock air filter setup, water pump, stock shift boot, door pockets, 2nd gen cam cover, transmission mount, rear motor mount, right motor mount, assortment of water hoses, 1 pair mirrors, Timing belt pulley wheel/spring/bracket/bolt, 5sp Transmission for parts or rebuild… more to follow
If you have any additional questions, PM me with your phone number.
If your using more than 3 cylinders your just wasting gas.
I spit on hybrids at stop lights.
PostPosted: Wed Sep 14, 2016 7:46 am
More parts pics
PostPosted: Mon Nov 07, 2016 10:08 pm
Entertaining offers on car with or without parts cache.
Will only sell parts separately if not sold with car
PostPosted: Fri Nov 25, 2016 1:21 pm
Please delete this posting.
Car is sold.
"Parts cache" will be for sell. Will re-post shortly in parts for sale Shipping will be using USPS Priority Mail. If it fits it ships.
