It is currently Mon Jan 16, 2017 12:40 pm
PostPosted: Thu Mar 29, 2012 7:23 pm
Curious what your getting for vacuum with the camshaft......
Thanx.
PostPosted: Fri Apr 06, 2012 9:53 am
i got one:) mmmmm fast
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Thu Mar 14, 2013 7:54 pm
bouncy at idle. no lower then 12inhg I think though
stage 2 cam (350/218) +8 sprocket
PostPosted: Fri Mar 15, 2013 1:24 am
Had one in roommate's car.... huge difference. But I will warn you if you try your damnedest you can suck enough fuel to drop to 26mpg! Under normal conditions, mileage was same . Goodluck
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Fri Mar 15, 2013 7:40 am
+1 on potential fuel usage increase
driving easy (1st gear at 3500 rpm, rest at 3k, hold vacuum at 7in hg during acceleration) I just pulled 49.1 mpg mixed driving (35-45 mph roads for city, 70mph for hwy). That is a personal best.
However when I was 'testing' my brakes (repeated rapid acceleration to 60, hard on brakes) fuel economy was 36 or so. personal worst.
PostPosted: Sun Apr 14, 2013 3:35 pm
I got a 365/222 for daily use, cute lopey idle, noticably more powerful and I love the sound. Won't pass MOT at idle, raw gas from the exhaust, especially when the engine is cold. Long drive at 130 kph gives me a mileage of almost 41, or 5,9l/100 km. I used to have the 350/218, which was slightly better in fuel consumption. Sorry, don't have vacuum readings.
'95 Swift 1.0:
- 0,5mm oversized pistons
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- TBI bridge removed
- srd underdrive pulley
- GTi catback
- deleted cat, now 2" ss pipe
- 14x6J ET45 BSA Racing
- Nankang AS-1 165/55-14
- GTi sway bar
- Turbinetech underbody brace
0-100kph: unknown seconds
PostPosted: Sun Apr 14, 2013 9:10 pm
I'm running a .375-226 and it runs like a raped ape
-91 Swift GTi 1.3 DOHC -wrecked now shell swapping to 1/4 mile car
-90 Metro 3/5 daily driver
