It is currently Sat Mar 17, 2018 9:05 pm
PostPosted: Wed Jun 14, 2017 7:13 pm
Was thinking of porting it and cutting the plenum floor to open it up. Is it worth it.
02 bmw 330ci zhp
'98 Chevy K2500
'76 Harley Davidson FXE
PostPosted: Sat Jul 29, 2017 12:51 pm
I'm not sure how restrictive the factory intake is but you can hook up a pipe to the edge of the intake plenum with a cone filter on the end eliminating the factory filter. I'm not sure if its possible to fit a larger throttle body on the car but if it is then you can try that as well.
PostPosted: Wed Aug 30, 2017 7:24 pm
I cut out the bulk of the housing, just enough plastic left to keep the filter clamped in. Seems to increase flow with both the stock filter and the K&N I have.
Edit: it should also be noted I guess that I have a bigger throttle body (45mm) as well, that changed the sound of the car for the better and really made a noticeable difference in power surprisingly.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
