It is currently Fri Mar 23, 2018 7:57 am
PostPosted: Sat Mar 03, 2018 5:49 pm
I have a 2001 Mk2 1.0 Swift GLS. The steering wheel is shot, I want to replace it with a cheap 'momo' style wheel and boss.
99% certain there is no airbag so should be straight forward enough to do.
Can anyone advise on how the wheel is removed (I think there is screw on the underside, is that it?).
Also if anyone knows the dimensions of the steering wheel shaft so I can find a suitable boss kit that would be great. Or recommend one you have used.
What about the horn wiring, just a 2 pin switch I assume?
Many thanks
PostPosted: Mon Mar 19, 2018 1:15 pm
If you remove your horn button (the big center piece of your steering wheel, just give it a firm tug) you'll find the 17mm nut that holds the wheel. Horn is just two wires. Hubs and wheels should be easy to find on the net. I used an Autostyle hub with a QSP wheel.
'95 Swift 1.0:
- 0,5mm oversized pistons
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- TBI bridge removed
- srd underdrive pulley
- GTi catback
- deleted cat, now 2" ss pipe
- 14x6J ET45 BSA Racing
- Nankang AS-1 165/55-14
- GTi sway bar
- Turbinetech underbody brace
0-100kph: unknown seconds
