It is currently Thu Feb 22, 2018 2:43 am
 Post subject: swap g13bb with g16b
PostPosted: Wed Jun 28, 2017 2:07 pm
Hi guys, i'm new here, shortly I bought a 98 justy with engine g13bb, at home I have a g16b derived from a vitara, my question is that I have to make modifications to mount that engine, apologize for my bad english i come from croatia :-P
 Post subject: Re: swap g13bb with g16b
PostPosted: Wed Jun 28, 2017 2:17 pm
Bolje ti je da nadjes G16b is nekog auta sa prednjom vucom i samo promenis glavu motora sa usisom i izduvom . Mnogo manji posao a skoro isti efekat
Its better to just swap G16B cylinder head with intake and exhaust from the FWD application on your G13bb block . Almost as good and don't have to go through G16b swap
EDIT: also make sure you get the performance cam from Mike for it , you will forget all about full swap
PostPosted: Wed Jun 28, 2017 3:12 pm
do you think is a lot of work to put the whole engine in??? did it get on the 4wd gearbox??? what about the electric sistem???
PostPosted: Wed Jun 28, 2017 3:53 pm
Well , that depends on many things . Intake and exhaust are probably adapted for rear wheel drive Vitara so you cant use it in Justy because they are pointing wrong way , G16B may have different transmission bolt pattern then your engine , so you will need FWD transmission for it . Generally electrical connections are same for G13bb and G16b FWD applications so its plug and play .
There are more knowledgeable members from EU that have done these swaps but you will have to wait little bit for them to chime in since this forum traffic is not what it used to be :(
PostPosted: Wed Jun 28, 2017 4:37 pm
noooooooooo you are telling me that my gearbox cant fix on g16b??? :cry: :cry: :cry: :cry: :cry:
maybe is better find an g13b but then i have to change the whole instalation right???
PostPosted: Thu Jun 29, 2017 2:54 am
G series engines should have same bolt pattern for the transmission. I am sure that info is on this site , just search for it to make sure.
Yes , DOHC wiring harness is different
PostPosted: Thu Jun 29, 2017 7:10 am
The bell housing bolt patterns are almost the same the top to bolts line up the bottom to are about an inch wider on the G16. There are adapter plates out there for swapping the G16 into samurais that might work for you but may need to rework some of the motor mounts since you would be moving the motor over about 1/2 inch.
1994 suzuki sidekick 4 door
PostPosted: Sat Jul 01, 2017 3:20 pm
is this the plate you are talking about???
http://www.ebay.com/itm/Suzuki-Sierra-S ... SwZjJU4-kq
another question, is it possible to put rear disc breaks into the 4wd??? does anyone made this???
PostPosted: Mon Aug 07, 2017 4:58 am
บาคาร่า
PostPosted: Mon Aug 07, 2017 3:55 pm
The best G16B swap for your 4wd Justy is to find a donor 93 Suzuki Swift sedan which came with the rare factory G16B AWD option. It uses the large frame cable shifted transmission that bolts right up to the G16B bellhousing.
