It is currently Mon Feb 19, 2018 7:40 am
PostPosted: Wed Jul 12, 2017 5:39 am
I am still driving around without a proper seal on the inner side of the hub of my car.
I contacted the Suzuki Dealer and waited 6 months for parts, but the end of the story is that the listed parts in the Suzuki Dealer database simply do not match so they were unable to help. The parts listed in their database simply do not match as the seal has smaller diameter, I need 62. Contacted main Suzuki parts office in my country but no lock.
Any suggestions for compatible vehicles?
PostPosted: Thu Jul 13, 2017 4:40 pm
Sorry to bother you, after some intensive googling I shopped this:
I am going to try this, outer dim is 62,15mm and tables says it's compatible.
PostPosted: Fri Jul 14, 2017 1:53 am
Have you tried Rockauto for 1985 Forsa? They seem to have 2 brands of seals in 62 mm specifically for your Suzuki.
https://www.rockauto.com/en/catalog/suzuki,1985,forsa,993cc+l3,1270910,brake+&+wheel+hub,wheel+seal,1860
Footnote Bi-Directional Lip Design
Housing Bore (Inch) 2.441
Housing Bore (MM) 62.000
Material Nitrile
Outer Diameter (Inch) 2.451
Outside Diameter (Inch) 2.451
Outside Diameter (mm) 62.260
Part Description Oil Seal
Part Type Seals
Series 220000
Shaft (Inch) 1.732
Shaft (MM) 44.000
Shaft Size (Inch) 1.732
Type 32
Width (inch) 0.315
Width (mm) 8.000
PostPosted: Sun Jul 16, 2017 1:13 pm
Interesting, will try the one I ordered, just ordered 1 sample...
May I ask what vehicles I can browse at Rock Auto That is compatible for parts?
I used CHEVROLET SPRINT, and SUZUKI SWIFT foreign.
