It is currently Fri May 24, 2013 12:00 am
PostPosted: Thu Jan 27, 2011 2:30 pm
I have a 1998 Chevrolet Metro 1.0L.
I need help with my clutch issue. Problem is the clutch no longer works. It just goes down to the floor without resistance until it gets near the bottom. Then it is VERY stiff and hard to press. Any ideas?
PostPosted: Thu Jan 27, 2011 2:44 pm
if you dont get an answer quickly, im sorry i cannot help you there.
if this is alright? i dont see why not
head to geometroforum.com
will get you answers quick
PostPosted: Thu Jan 27, 2011 2:56 pm
Thanks!!! This place looks kind of dead nowadays.
PostPosted: Thu Jan 27, 2011 3:15 pm
I'm guessing you checked to see if the cable broke. Can you shift with the engine running? It could be the springs on the pressure plate broke but not likely.
PostPosted: Thu Jan 27, 2011 5:32 pm
Cable is not broken. I can shift with the engine running but the gears scrape.
PostPosted: Thu Jan 27, 2011 5:53 pm
did i see the time on your first post at 2:30 and 26 minutes later, at 2:56, post the above?
sorry, i don't get home from work until 4:30. :razz:
you may have a broken yoke or the throwout bearing might have fallen off. with the wee bit of info you gave us, it might also be that a spring has dislodged from the clutch hub and is bound up in the pressure plate.
whatever, there's no "fix in a can" and your only approach is to pull the transmission and have a look.
1991 Blue Geo Metro Convertible highly modified 1.0L Turbo3 5 spd. - 2000 Chevy Metro 1.3L MPFI automatic. - 1991 Red Geo Metro Convertible customized 1.0L 5 spd.
PostPosted: Thu Jan 27, 2011 7:56 pm
Does the pedal pull itself back up?
Pop the hood, and grab the clutch actuator arm, and work the clutch manually. What happens?
PostPosted: Thu Jan 27, 2011 8:13 pm
This reply has my vote.
Did you ever solve your low idle problem?
Sounds like it needed an MCS, but you didn't provide any feedback.
How about the muffler? Have you replaced that...it's been a while, eh?
You can find a lot of answers on other sites, especially if you post a video of your complaint.
Well, back to cleaning hydraulic lifters I go. Hope you solve your problem. Plan on $110 for a new clutch if you replace it yourself (clutch, pressure plate, throw-out bearing) or around $500 for a shop ($250 in parts, $250 in labor).
Gas prices being the way they are, I wouldn't complain, if I were you... :shock: :shock: :shock: as you own the highest gas mileage car available... :lol: :lol: :lol:
PostPosted: Thu Jan 27, 2011 9:16 pm
My idle problem remains unsolved.
I replaced my muffler.
Gas prices... You bet. That's why I'm resurrecting my metro.
Thanks.
Okay, thanks everyone for your responses.
I'll pull the actuator arm in the morning to see what happens. The pedal does return.
PostPosted: Tue Apr 03, 2012 7:34 pm
Anyone know where I can find a change clutch/pressure plate how-to for a 1998 Chev Metro 1.0 liter 5 speed?
PostPosted: Tue Apr 03, 2012 10:03 pm
Start here:
viewforum.php?f=9
...and make sure NOT to click on any of the links in my signature...
