It is currently Sat May 18, 2013 12:36 pm
 Post subject: 60mm Throttle Body???
PostPosted: Sun Jan 31, 2010 2:15 am
Senior Member
Was digging thru stuff tonight and ran across a 60mm throttle body. Does anyone use those any more? I had one on my '00 Metro 16v SOHC.
Mike
2006 Ion Redline Competition --- HP>MPG
2012 Prius Four Solar Plus Performance --- MPG>HP
PostPosted: Sun Jan 31, 2010 11:40 am
i use one on my gt, its an sr20 60mm, made a huge difference when i put it on.
02 Aerio 2.3 swap Wife's car
PostPosted: Sun Jan 31, 2010 11:50 am
Senior Member
I was surprised to find it on my shelf buried under a bunch of other stuff. Wonder if someone would want to buy it. What's the going rate these days?
Mike
PostPosted: Sun Jan 31, 2010 2:42 pm
A legend in his own mind
Mike
Holy shit!
Mike?
You still alive?
:lol:
2013: this is gonna be an interesting year...
LNLC Founding Member
PostPosted: Sun Jan 31, 2010 2:48 pm
Senior Member
Oh yea. My old '00 Metro is sitting in southern Minnesota. The guy is taking good care of it. I have my '06 Ion Redline with some tweaks. What's new up north? Getting ready for a Florida trip to escape this freakin Arctic cold.
Mike
PostPosted: Sun Jan 31, 2010 2:57 pm
You tell us, you're quite a bit north of us.
PostPosted: Sun Jan 31, 2010 3:01 pm
Senior Member
Hey Mike,
You got any use for a 16v SOHC stock cam and or a stock cam pulley? I have those here. Also a set of stock injectors and a stock fuel rail.
Mike
PostPosted: Sun Jan 31, 2010 3:37 pm
Those cams are pretty easy to find these days, but I can always use good cores.
PostPosted: Sun Jan 31, 2010 3:56 pm
I could always give the unwanted throttle body a loving and caring home... =)
PostPosted: Fri Jan 28, 2011 7:58 am
Mike
I have a 60mm throttle body from SR20DE engine in my gti. In addition I change stock intake pipes into new pipes with bigger diameter. I use also K&N replacement filter. Thanks to this intake operating parameters were improved. Max power increased 3,6 [HP] and torque 7,5 [Nm]. Moreover horse power and torque increased in all range speed.
In the evening I put some photos with my air intake system.
Greetings,
Michael
http://www.facebook.com/JDMsTamagotchi
PostPosted: Fri Jan 28, 2011 9:07 am
Senior Member
Holy revive a thread from the past :bump:
Mike
PostPosted: Sat Apr 23, 2011 11:25 pm
Mike
Well you've disabled Private Messaging and there is no direct way to contact you unless you have subscribed to this thread. In that case, I wanted to know if you still have your 60mm TB around somewhere.
PostPosted: Sun Apr 24, 2011 12:06 am
Senior Member
Yes the TB is here. I will check the PM settings and get things updated so you can get a hold of me. Sorry.
Mike
PostPosted: Fri Jul 15, 2011 4:53 pm
Sad but True...
Holy Crap you are alive!
As for the 60mm tb. well I'm a skeptic. I had one. I think a 50MM tb is large enough. a 60mmtb is way to big for a 1.3L. There is a better way of explaining it,,something about velocity??
"One Of Three ORIGINAL LNLC Co-Founders"
1991 Suzuki Swift GT.
1994 Suzuki Swift GT.
PostPosted: Fri Jul 15, 2011 5:27 pm
Senior Member
Tony? It's been a real long time. I sold that 60mm TB to a fellow out west. Don't remember who. How you been doing and are you still driving the Metro/Swift cars? I still have my Ion Redline. Gonna trade it in next June for something fuel efficient. It eats 92 octane gas like crazy.
Mike
PostPosted: Sun Jul 17, 2011 12:26 am
Sad but True...
Dan,,you were close though! :-P I remember all the talks on the LNLC and when you decided to get your Saturn. Wow,,,time flies!
PostPosted: Sun Jul 17, 2011 1:35 am
Senior Member
Sorry I screwed up on your name. I know there was a Tony somewhere =) Yea my Ion turned out to be a good car. Only got 10,500 miles on it but not a lick of trouble. Got me some different injectors, smaller pulley, software, additional heat exchanger and boy she's a handful to keep on the road when she comes on the pipe :twisted: Should be good for mid 13's in the quarter but I won't bring her to the track.
LNLC, was that a chat room thing we did way back then? I recall the name but don't remember anything else. Have you seen that guy who bought my old '00 Metro on here? Last I heard he got it to run high 14's I believe?
Heck, I just noticed it is coming up on 10 years of me being on this forum. Holy crap that is a long time :buzz:
Mike
PostPosted: Sun Jul 17, 2011 4:52 am
Mike
Only an ex swift guy would think an ecotec powered car is a gas guzzler :lol:
PostPosted: Sun Jul 17, 2011 10:34 am
Senior Member
No doubt :razz: How you been doing Mike? Did winter finally end up there in the north woods 8)
Mike
PostPosted: Sun Jul 15, 2012 11:35 pm
I don't mean to break up the party here, but I want to ask a real noob question. On the stock TB I know the size is 45mm. Now is that the size at the TB plate or at the inlet? If it's the size at the plate, what is the size of the inlet? I measured mine and it was 60mm.
Nick Manning
2006 Scion xB (fun-mobile)
PostPosted: Mon Jul 16, 2012 6:12 am
The plate is 45 mm on a 45 mm tb
PostPosted: Tue Jul 17, 2012 1:03 am
When talking tb diameter its the id of the bore at the throttle plate. Did you measure od of the inlet?
I always have this 83mm q45 tb sitting here. Overkill much?
Maybe the stock dual 57mm tb off my mustang?
98 swift big block
