It is currently Sun May 19, 2013 1:03 am
PostPosted: Tue Jul 05, 2011 2:55 pm
:D I have a Suzuki swift 94
G13B 8v 192.400km
5 speed gearbox R serial, i dont know ratios :?
No A/C
GTi bumper
GTI fog lights with oem switch
Personal steering wheel 350mm (Before in Suzuki Cultus)
GTI Adjustable steering wheel
Swap.....GTi complete setup! 8) 8) 8)
GTI cluster
GTi Harness oem ECU and electrical
F5 ECU
GTI air filter box OEM with K&N air filter and MAF sensor
TPS sensor
GTI igntion coil
GTI intake manifold EFI
twin cam cylinder head (EPI) cams
GTI rear disc brake- OEM
GTI cast iron exhaust manifold - OEM
Custom exhaust system
GTI muffler - OEM
maybe GTI seats
:wink: more pics....to be continued
ALEX SAN
Suzuki Swift GL ---> GTi Swap
Honda Civic Si
Honda Fit
Suzuki Cultus <Sold>
PostPosted: Tue Jul 05, 2011 2:57 pm
i'm waiting for updates. good going :mrgreen:
PostPosted: Sat Jul 09, 2011 9:18 am
process begins...
GTi electrical harness installed
ECU and harness installed
ready!!
ingtion coil isntalled
internals engine parts
block
before pistons and crankshaft 1.3 8v sohc
now!! :lol: GTi
new oil pump Suzuki Genuine Parts
new cover
MAF support installed
valves cover
GTi Cluster ready!! 9000RPM :mrgreen: :mrgreen: :mrgreen:
GTi Adjustable steering wheel
the cylinder head is in process...
The cylinder head is in cleaning process and assembling....
the next update will be engine completed!!
ALEX SAN
Honda Civic Si
Honda Fit
PostPosted: Sun Jul 17, 2011 12:36 pm
motor ready!
OEM GTI throttle body.... :twisted: soon upgrade!!!
OEM GTi timer
OEM GTI muffler
OEM GTi rear discs swap
:| :shock: :? :roll: soon new shocks :twisted: and lowering springs
ALEX SAN
Honda Civic Si
Honda Fit
PostPosted: Fri Oct 21, 2011 10:15 pm
Is the in tank fuel pump a direct swap or u have to change the complete tank? Im asking cause Im looking to swap my 8v carb with a gti engine also. Thanks :D
PostPosted: Sat Oct 22, 2011 4:03 pm
new GTi tank, but the fuel pump fix on 8v tank
ALEX SAN
Honda Civic Si
Honda Fit
PostPosted: Sat Oct 29, 2011 10:25 am
I posted some comments about your car (using my spanish), but my comment got deleted. Anyway here goes again.
I am doing the same sort of conversion as yours, I got a convertible 1.0 going GTI. I have finished most of the project myself, I am at the point where I can get the car started. I got a few missing connectors that I still need to make sense of. Thanks for your pics they have help me to setup my connectors in the right spot. I was wondering if you have any pics of the water pump setup, looks like a couple of sensors got removed from mine, and I would like to confirm that. I am using customized headers on mine, however I am missing the oxigen sensor that goes in there too. I am using the convertible transmission instead of the GTI one.
After making the change, how does it feel the handling and cornering in yours?
Monte
Monte
Audi A4 Cabriolet 2.0 T 2008
Chevrolet Sprint CL 1991 Convertible 1.3 GTI
Honda Pilot EX 4WD 2006
Honda odyssey EX 2013
