It is currently Sun May 19, 2013 6:23 pm
PostPosted: Mon Apr 09, 2012 6:18 pm
im looking for a new intake manfold n maybe throttle body?? idk not sure, but idk what ones are the best for my 1.3 metro
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Mon Apr 09, 2012 10:23 pm
Pick up an esteem 1.6 tb. Don't worry about the manifold.
98 swift big block
PostPosted: Mon Apr 09, 2012 10:38 pm
whould u know a website?? if posible
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Mon Apr 09, 2012 11:42 pm
Your intake manifold is already designed for maximum flow. It's simlilar to the suzuki cultus intake. But a restriction is the stock throttle body it was just designed for fuel economy. What you can do is bore out your throttle body intake with a machine and port match the intake hole on your intake side. I've done mine to 55mm, but I only have the 50mm throttle body [from suzuki esteem] on there now as the one I hooked up did not have a perfect seal and so my idle speed was like at 2K lol.
Suzuki RD sells bigger ones, also there is a website called maxbore which does a more professional job than what I tried to do at home.
PostPosted: Tue Apr 10, 2012 10:29 am
soo i should just get mine t.b. sent to that place? n they hollow it out?
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Tue Apr 10, 2012 10:39 am
The only similarities between that intake and the Cultus intake is that they're both made of steel. The Esteem TB is 45 not 50.
PostPosted: Sun Apr 22, 2012 11:22 pm
Senior Member
I used to run a 60mm TB on my '00 Lsi :twisted: It ran very nice. Guess you could search for my old posts if they are still on the forum. I recall I did post a lot of info on what I did to make it fit and function. It took a lot of grinding on the TB flange and I also ground down the bumps in the runners right at the head flange. Mike can set you up with the hardware. I sold my last 60mm TB a year ago I believe. Nothing but the memories left :razz:
Mike
2006 Ion Redline Competition --- HP>MPG
2012 Prius Four Solar Plus Performance --- MPG>HP
PostPosted: Mon Apr 23, 2012 11:13 am
Mike
yes but all your old photos are broken. do you think you could go back and fix them ?
PostPosted: Mon Apr 23, 2012 12:14 pm
well make another 60mm tb n ill buy it:)
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Mon Apr 23, 2012 12:45 pm
Senior Member
I just got done searching my drives here and found those pictures must be on an old drive which I no longer have or it's buried somewhere. It appears this forum went thru a server change or something since my original posts and the uploaded pictures got deleted but the posts were moved over. The last I knew my old '00 Metro was owned by a fellow in Southern Minnesota. I don't know if he is on this forum or not. He used to email me every so often with updates or pictures of the car but I haven't seen an email in a few years and don't remember who he is. About the best advice I can give is call Mike Cove up and see what he can help with.
As far as old parts, I sold off the other 60mm TB last year I believe to someone on this forum. I believe it went to Washington state or Oregon. The Pacific NW anyhow. I have left a stock 16v SOHC cam, a stock set of injectors, fuel rail with harness, and one set of rear stainless braided brake lines left over from the Paragon Performance braided brake line build. There are a couple TB's on the shelf but they are not 60mm and I don't know exactly what I did to make the Nissan TB's fit the 16v SOHC intake, TPS, throttle cable & idle control. It was all hand made parts and mods to make it fit & function. It sure fit and functioned nice though :razz:
Mike
PostPosted: Mon Apr 23, 2012 12:55 pm
Mike
how bout them brake lines?? post pic? ill pick em up if there nice :)
my shit leaks
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Mon Apr 23, 2012 1:03 pm
Senior Member
my shit leaks
I will post pics before dinner time. I have to eat lunch and pick my son up at school then I can get the pics taken and posted. They are DOT certified in case you are wondering.
Mike
PostPosted: Mon Apr 23, 2012 1:12 pm
what do u mean??
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Mon Apr 23, 2012 6:52 pm
Senior Member
Here are the brand new unused 95-01 Metro rear brake lines made by Paragon Performance in California. Both are 14.5" long Teflon lined stainless braid.
Let me know if your interested $59.00 shipped to US or Canadian address's. Paragon Performance sells front sets separately.
http://www.paragonperformance.com/chevymetro.html
Mike
