I just got done searching my drives here and found those pictures must be on an old drive which I no longer have or it's buried somewhere. It appears this forum went thru a server change or something since my original posts and the uploaded pictures got deleted but the posts were moved over. The last I knew my old '00 Metro was owned by a fellow in Southern Minnesota. I don't know if he is on this forum or not. He used to email me every so often with updates or pictures of the car but I haven't seen an email in a few years and don't remember who he is. About the best advice I can give is call Mike Cove up and see what he can help with.
As far as old parts, I sold off the other 60mm TB last year I believe to someone on this forum. I believe it went to Washington state or Oregon. The Pacific NW anyhow. I have left a stock 16v SOHC cam, a stock set of injectors, fuel rail with harness, and one set of rear stainless braided brake lines left over from the Paragon Performance braided brake line build. There are a couple TB's on the shelf but they are not 60mm and I don't know exactly what I did to make the Nissan TB's fit the 16v SOHC intake, TPS, throttle cable & idle control. It was all hand made parts and mods to make it fit & function. It sure fit and functioned nice though
Mike
