It is currently Wed Oct 18, 2017 3:53 pm
PostPosted: Tue Sep 12, 2017 4:47 pm
So it's been almost a year since disassembley and I lost my oil feed line banjo bolt which attaches to the block to feed the turbo.
I'm so close but without this bolt I'm a million miles away.
Please help a brother out
PostPosted: Wed Sep 13, 2017 2:12 pm
Found a banjo bolt in town but I need to know the internal hole size so I can fill this one and drill it to the appropriate size.
PostPosted: Fri Sep 15, 2017 6:48 pm
Found my original bolt. But if anyone ever needs to know the hole is 77/1000ths on my dial caliper not sure what that translates to.
PostPosted: Fri Sep 15, 2017 11:36 pm
Glad you found it. :thumbsup:
79/1000 is 2.00 mm.
PostPosted: Sun Sep 17, 2017 3:38 am
Yeah I feel better having the original bolt.
I appreciate the conversion to mm, thank you.
PostPosted: Sun Sep 17, 2017 2:38 pm
So I measured the hole in the bottom of the bolt but the hole at the top is 1.25mm. Just wanted to make sure I out the correct info out there.
