It is currently Sun Jan 25, 2015 1:18 pm
 Post subject: Automotive math
PostPosted: Sun Mar 14, 2004 10:12 am
There are a few questions that keep coming up, so hopefully this will answer some of them.
Displacement
Pi x radius of the bore squared x stroke x # cyl.
since displacement is expressed in cubic centimeters, then dimesions must be also in cent.
Example:
74mm bore becomes 7.4cm. Radius would be 3.7cm
3.7 x 3.7(radius sq) x 3.14(pi) = 42.986
42.986 x 7.7(stroke in cm.) = 330.9968
330.9968 x 3 (# of cyl) = 992.99046
Want to put 4.39's in your car, but don't know what it will do to your cruise RPM?
RPM = MPH x axle ratio x 336 / tire diameter.
fifth gear in our trannies is .76-1, so the final drive in fifth is .76 x selected ratio(4.10, or 4.39) Auto trans. are 1-1 in 3rd. gear.
Example
RPM = 60 x 3.12(4.10 x .76) x 336 / 22.74 (185 60 14 tire dia.)
RPM = 2766
Don't know what axle ratio you have, but have a tach?
Axle ratio = RPM x Tire dia. / MPH x 336
1 KW = 1.34 HP
Hope that helps.
PostPosted: Fri Apr 02, 2004 10:17 pm
various automotive calculations
http://www.bgsoflex.com/auto.html
PostPosted: Sat Apr 03, 2004 5:49 pm
sweet ;)
keep it going
PostPosted: Sun Apr 04, 2004 8:06 pm
sweet
keep it going
OK, here you go...
http://www.prestage.com/Car+Math/default.aspx
PostPosted: Thu Mar 17, 2005 8:30 pm
Sparky
IF I change my tires and wheels to 17" How off will my Speedo be? Check below
http://www.miata.net/garage/tirecalc.html
My Car Weighs 1800lb wit me in it, How Much HP do I need to put on the ground to run 10's????? see below
http://www.torinocobra.com/horsepower.htm
What other Cars have the Same Bolt pattern as mine?
http://www.wheelcollision.com/cta.htm
Looking for Parts in Junk Yards
http://car-part.com/
A few I have book marked
PostPosted: Tue Mar 22, 2005 3:58 pm
Sparky
Here is some Extra info I got for the 88 Sprint
Exterior Dimensions & Weight
Metro Coupe Sedan Turbo coupe
Curb Weight - Manual (lb.) 1565 1565 1620 1620
Wheelbase (in.) 88.40 88.40 92.30 88.40
Length (in.) 144.50 144.50 148.40 144.50
Width (in.) 60.20 60.20 60.20 60.80
Height (in.) 53.10 53.10 53.10 53.10
Track Front (in.) 52.60 52.60 52.60 52.60
Track Rear (in.) 51.20 51.20 51.20 51.20
Info pulled from Below Link
http://autos.msn.com/research/vip/overv ... b=0&sub=-1
PostPosted: Wed Sep 27, 2006 8:56 am
Sparky
This has a lot of good links, I think it should be a sticky!!!! :twisted:
PostPosted: Wed Sep 27, 2006 1:13 pm
And so it shall be..
PostPosted: Wed Oct 25, 2006 2:28 am
Sad but True...
Here is a Link to find out what you would do ROUGHLY in a 1/4 mile if you only did the 1/8 mile.There are MANY different calculators here.
http://www.wallaceracing.com/Calculators.htm
1991 Suzuki Swift GT.
1994 Suzuki Swift GT.
 Post subject: Re: Automotive math
PostPosted: Mon Aug 25, 2008 1:34 pm
Wow, this helps so much. I used to know all of these calculations, because I learned them from my grandfather years ago (he owned a transmission shop for 35 years). But, I've long since forgotten them. Thanks superf1y! And thanks to Kento for the bookmarks. I added them to mine as well.
1994 Suzuki Swift GA hatchback - hopefully will be a GTi soon! Please help me find a G13b with ECU!
